Activity Forums Compression Techniques DPX codec for Qtime Player?
  • DPX codec for Qtime Player?
    Posted by Aaron on October 24, 2006 at 8:50 pm
    Apparently this format was big for high end digital film transfers in the late 90’s and kind of went away. I got a client now who can only provide me an animation in this file format. Is there a secure site someone can direct me to or info as far as where I can get a reliable form of this codec for the QTime player on MAC OSX? It would be for an FCP edit at HDCAM 4:2:2 1920x1080i
    Much appreciated
    Aaron
    Ikarus79m replied 19 years, 10 months ago 4 Members · 3 Replies
  • Charles Simonson
    October 25, 2006 at 1:05 am
    If you have a Decklink or Kona card, then you may be in luck as they support DPX to SDI I believe. Play the DPX out via SDI and either record it and then capture or loop from the deck to another station that can record the signal. Another option may be to open the DPX images in QT as a sequence and then try to export that an umcompressed QT movie. It has been a while since I last worked with DPX so I am a little rusty. Hopefully that will help.
  • Illclinton
    October 25, 2006 at 3:29 am
    Hey Aaron,
    Download the latest Kona driver (https://www.aja.com/html/support_kona3_swd.html), which will include a DPX to QT converter. If you have access to Smoke or Combustion, it can take DPX sequence and convert it to .mov or .avi.
    Call me if you have any questions.
    Kenji from Rough House
  • Ikarus79m
    November 5, 2006 at 7:53 am
    There is a Cineon/DPX Quicktime Component.I think that is what you might be looking for. Go here for a demo version:
    https://www.gluetools.com/
    Philipp
