Activity › Forums › Adobe After Effects › DPS reality with AE…anyone…
Posted by Jennifer on July 20, 2005 at 1:30 pmHello,
Does anybody use a DPS reality board for video import/export with AE? I have questions for anyone I can find who uses this?
Jen OAroonzfx replied 21 years, 2 months ago 3 Members · 3 Replies -
Clint Fleckenstein
July 20, 2005 at 2:53 pmI do, but I use the Velocity software package on it. You can use just Reality if you wish, I suppose. You need the AE I/O plugins which can be downloaded from the Leitch/DPS website.
Clint
Jennifer
July 20, 2005 at 3:37 pmI have been using it for many years actually and just started using the actual DPS codec to render directly to a DPS file, much easier. (I used to have to create a targa sequence in DPS, just black frames, and then I would render a targa sequence out of AE and replace each frame when rendering) I can not figure out how to render audio out of AE as a DVA? I am rendering the animation to DPS then I export a wav. file out of AE and load that into DPS. Is there a way to render audio and video together out of AE?
Also we are running into a huge problem with sharing AE projects between work stations that have DVAs in them. It won’t let us open the project on a new work station, it crashes. Any help would be huge!!
Jen O -
Aroonzfx
July 20, 2005 at 5:23 pmhi
our channel also hav the dps velocity and dps realitythe plugin are acutally outdated ones.. the new plugins is not yet released …
i also used to render large targa sequences adn then import it using dps reality as dps files
but with the plugin i am rendering straight to dps files…
i also tried rendering out to dva files…
eventhough time line had music in it and i selected dva frm the output module, it didnt work… it gives some error message…i think the main prob is with the outdated plugins …
wish leitch gives out the new plugins 🙂by teh way
what is your dps velocity adn reality version ???
and are you using ae 6.5 ??i will try to find it somehow ..
aroonz
