Activity › Forums › Apple Final Cut Pro Legacy › downgrade FCP 6 to 5
Posted by Francois Stark on November 6, 2007 at 3:02 pmI have a client who purchased FCStudio2 (FCP 6). He delivers work that we have to “finish” and play out after final mix. However, we have 8 suites, all on FCP 5.
So is there an easy way to downgrade to FCP 5? How do I uninstall FCP 6 to re-install FCP 5?
FrancoisAlan Michel replied 16 years, 7 months ago 7 Members · 10 Replies -
Shane Ross
November 6, 2007 at 3:32 pmHow do you finish the project? What steps do you take?
You can export an XML of the cut from FCP 6 and FCP 5 can recognize that. I believe XML V2.
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Lee Berger
November 6, 2007 at 4:06 pm -
Aaron Zander
November 6, 2007 at 4:32 pm[Lee Berger] “FCP 5 will open XML version 3”
actually fc v5 (the base version) will only go to version 2.0 I believe, but going as far as 5.1.4 will open all the way to the second highest (is that xml version 5?)
Lee Berger
November 6, 2007 at 5:26 pmThanks. I was able to open a version 3 in 5.1.4, but not version 4
Lee Berger
http://www.leebergermedia.com -
Russell Lasson
November 6, 2007 at 5:34 pmWe use XML all the time to transfer sequences between 5 and 6. It’s worked really well.
-Russ
Francois Stark
November 6, 2007 at 7:12 pmHi all
Thanks for the input, but nobody answered my question…How can I uninstall FCS2 in order to re-install FCS1?
And yes, we have been using XML V3 to get projects from FCP 6 to FCP 5.1.4. It works pretty well, except for all our boris 3D titles that get replaced by gradients. We also stay away from speed changes, since we all know that reconnecting media on speed changed clips are unpredictable. And the xml process forces FCP to reconnect to the media.
I suppose the best way to uninstall would be a clean re-format and install. I suppose I’ll have to go over to leapard on the client’s system, re-install MS office, pull all the email over, copy all documents, and then install FCP 5, upgrade to 5.1 and then up to 5.1.4.
How does FCP 5.1.4 run on leopard? Does quicktime use the same version on 10.4 and on 10.5? I suppose that would be quite a rare installation…
Regards
Francois -
Garrett Bradley
June 7, 2008 at 7:37 pmHi Russ,
You wrote that you have experience transfering projects from FCP 6 to FCP 5. I am trying to do exactly that and keep coming across an alter asking me to choose a transitional format of sorts. Any suggestions on how to take my final project which has been mixed in 6.1 and bring it back onto my own computer which has 5.1.4 using an xml?
Thanks! -
Alan Michel
February 11, 2010 at 5:50 pmHi Russ,
Can you give me some tips on how to do this. We are working in High Schools that have mixed versions of FCP and we are always running into problems with incompatibility on various machines.
I appreciate your help.
Alan
Alan Michel
HOME, Inc.
