Activity Forums AJA Video Systems downconverting DVC Pro HD to DV NTSC
  • downconverting DVC Pro HD to DV NTSC
    Posted by Joe Linton on May 31, 2006 at 4:29 pm
    What is the best way to downcovert DVC Pro HD to DV NTSC? And what frame size should I make it if I want it letterboxed? My HD sequence settings are as follows: 1280×1080 [HD (1280×1080) 16:9 ] and the capture frame size is 1920×1080. All the footage was captured via Kona 2 thru a Panasonica AJ-HD1200a VTR using the DVC Pro HD codec (1080i 29.97) as you may have assumed. When I export short clips to post on a server for client approval, the frame size that I found works is 480×270 — to maintain the current apsect ratio. Any ideas to lead me in the right direction will be greatly appreciated.
    Thank you in advance,
    Joe Linton
    Jeremy Garchow replied 20 years, 4 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    May 31, 2006 at 10:21 pm
    Use the real time down convert on the Kona 2. open your control panel, set your preferences (letterbox, anamorphic, crop, or otherwise) and record in real time to tape.
    Jeremy
