Activity Forums Apple Final Cut Pro Legacy Downconvert HDV 1080 50i to DV PAL 25i
  • Downconvert HDV 1080 50i to DV PAL 25i
    Posted by James Skinner on August 17, 2006 at 11:59 am
    Hi All,
    I have an HDV 1080 50i sequence (upper field first) in FCP 5.1 that I need to convert to dv pal widescreen /anamorphic 25i (lower field first), can anyone tell me the best way to do this? My primary concern is interlacing issues. Is it best to export direct from timeline to dv format, via compressor, or to simply drop my HDV sequence into a Dv Pal timeline? Or Do I need to deinterlace then export?
    Many thanks, James
    (cross posted to hdv forum)
    Ben Holmes replied 20 years ago 2 Members · 1 Reply
  • Ben Holmes
    August 17, 2006 at 12:13 pm
    Do you need to keep working on the footage at DV quality? If you’ve finished working on it, I would recommend exporting your sequence as a QuickTime movie using the DV compression settings. This will automatically reset the field ordering as well. Don’t use the deinterlace.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    Producer/Director “The Supercar Run” now available for international distribution from http://www.electricsky.com
