Activity › Forums › AJA Video Systems › Downconvert Audio-Crackling
  • Downconvert Audio-Crackling
    Posted by Eric Sternberger on October 27, 2009 at 11:51 am
    Recently we got a strange issue here with our Kona 3 System (2007 MacPro)
    We have 1920×1080 ProRes (SQ) Files. Codec, Sequence & Project-Settings matched.
    When we switch the Video settings in FCP to 1080i 10bit we get nothing but garbage on our preview monitors. (one is a Sony Class1 CRT connected via SDI using the downconverted SD-Signal, the other is a Samsung LCD connected via component using the HD-signal) But: On both monitors just garbage.
    When we switch to 1080 8 bit Video works (on both monitors), but we get Audio-Crackeling playing the timeline. (Audio monitored over Kona)
    I was under the impression that ProRes is 10 Bit! So why the issues? And what has it got to do with audio?
    We recently upgraded to Control Panel 7.0. I´m not sure, but I think I havent seen this before that…
    Eric Sternberger replied 16 years, 11 months ago 2 Members · 4 Replies
  • Gary Adcock
    October 27, 2009 at 12:13 pm
    [Eric Sternberger] “I was under the impression that ProRes is 10 Bit! So why the issues? And what has it got to do with audio?
    We recently upgraded to Control Panel 7.0. I´m not sure, but I think I havent seen this before that… “
    Eric
    this is one of those – I think you downloaded the driver, but forgot to update the firmware on the card.
    the firmware update on the Kona 3 Card is a manual process.
    Applications > Aja Utilities > Kona Firmware updater.
    [Eric Sternberger] “When we switch the Video settings in FCP to 1080i 10bit we get nothing but garbage on our preview monitors. “
    when you change the compression version you need to change the Video Out preset also
    Question : why are you converting to UC when working with ProRes files- this is unnecessary the way ProRes was designed..
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Eric Sternberger
    October 27, 2009 at 1:47 pm
    Hey Gary,
    appreciate that you are still up 🙂
    Just updated the firmware, it was already the 64bit Version but it was still outdated (I wasn´t aware there was a newer one)
    But the problem persists: No Preview with 10bit Display-Setting, only works with 8bit…
    BTW: I´m not recompressing to UC, I stay ProRes. It´s just the display-setting (in FCP)
  • Gary Adcock
    October 27, 2009 at 2:20 pm
    [Eric Sternberger] “But the problem persists: No Preview with 10bit Display-Setting, only works with 8bit… “
    and you are using the EASY SETUP for your flavor of video and ProRes.
    this was an issue in the very first 6.0 driver, I have not seen it on the Kona 7.0 driver.
    Make sure you DID NOT install the 64bit driver – correct?
    gary adcock
    Studio37
    Chicago, IL
  • Eric Sternberger
    October 27, 2009 at 3:02 pm
    The firmware now is: 2008/12/17
    The footage was captured on another machine with the “HDV to ProRes”-Easy Setup.
    It is 1440×1080 25fps Apple ProRes 422
    On the editing-machine we used the AJA 1080i 25 ProRes 422 Easy-Setup for the project. With that we have no Preview. Only when stopped or during scrubbing we see a picture.
    When we switch the display-settings to 1080i 8 bit, it works though, but we have crackeling sound…
    I also uninstalled & reinstalled the 7.0 driver.
    Or is the HDV-ProRes conversion the culprit? It was done with the proper easy setup though…
