Activity Forums Apple Final Cut Pro Legacy Down Scaling HD project for SD DVD- AE or Compressor?
  • Down Scaling HD project for SD DVD- AE or Compressor?
    Posted by Sascha Engel on May 3, 2012 at 8:30 am
    I guess, that is an ongoing Q for a time: I finished a rock concert, shot in full HD, edited & graded in FCP 7.
    Now, have to down scale it the best way possible to an SD File, for creating a SD DVD.
    Here are my two options:
    1. Taking the final Online File (Apple ProRes 422) to compressor directly and using the resize filter in there at Best setting to create the DVD File in SD
    2. Taking the HD File to AE, resizing there and then take that SD ProRes File to Compressor for encoding for DVD.
    I really need the best resizing solution fo this two: we see a lot of close ups of guitars, and guitar strings usually, when not resized properly look terrible very easy.
    Thanx for any input.
    Greetz,
    Sascha
    Brent Hilgenkamp replied 14 years, 1 month ago 8 Members · 16 Replies
  • 16 Replies
  • Chris Tompkins
    May 3, 2012 at 11:01 am
    I’ve seen arguments for both options.
    Can you test a short clip to see?
    Chris Tompkins
    Video Atlanta LLC
  • Michael Gissing
    May 3, 2012 at 11:34 am
    I have no direct comparison but a lot of people have reported that AE is better than Compressor for scaling.
    My preference is to use my Kona3 card and it is also the quickest.
  • John Pale
    May 3, 2012 at 4:54 pm
    Make a short test file of your most challenging material and compare.
    In my experience, I have found Compressor, when using the Frame Controls set to Better or Best, does an excellent resize. I also found doing the downscale first…and not trying to do it combined with the MPEG-2 encode, results in better quality. Make an SD intermediate, either Uncompressed or Pro Res, then encode that to MPEG-2. If its a relatively short piece, use CBR for the MPEG encode and not VBR.
  • Sascha Engel
    May 3, 2012 at 4:59 pm
    HI GUys,
    thanks for sharing all your advice.
    I usually never use VBR, but CBR.
    I do now 2 tests: One with Compressor and one resizing in AE and then encoding in compressor.
    Will let you know, what version comes out better.
    Greetings,
    Sascha
  • Sascha Engel
    May 3, 2012 at 5:13 pm
    HI John,
    out of curiosity, when you do CBR, what is the max Average Bitrate you choose?
    I know, that some cheaper DVD Players cannot handle too much. I try never to go over 7,5 MBs.
    Is that a reasonable value?
    Thanx.
    Sascha
  • John Pale
    May 3, 2012 at 9:56 pm
    I usually set my CBR no higher than 7. Any higher is asking for trouble with burned DVDs.
    Also use AC3 for your audio instead of Aiff/PCM.
  • Sascha Engel
    May 4, 2012 at 3:32 pm
    Hi GUys,
    for future encounters with that issue:
    My test shows, that the first AE downscaling to SD and then encoding with compressor wins a tight race over the direct in compressor encoding.
    The difference is minimal, but there is less Moire issues and less problems with thin lines and stuff like this.
    Overall a bit cleaner. Taking a little longer, but not much at all.
    Sascha
  • Michael Gissing
    May 4, 2012 at 11:55 pm
    Thanks for the update Sascha. It confirms previous wisdom espoused here.
  • Sascha Engel
    May 5, 2012 at 12:20 pm
    more than welcome!
  • Eric Pautsch
    May 6, 2012 at 9:30 pm
    Ive been using this workflow using Avi Snyth for several years now and will absolutely blow away and down converting methods on the book
    https://www.precomposed.com/blog/2009/07/hd-to-sd-dvd-best-methods/
    Also here’s a good tutorial video:
    https://bellunevideo.com/tutorials/hd2sdTutorial/hd2sd.html
    its PC only but its all freeware
