Activity › Forums › Apple Final Cut Pro Legacy › Down converting HDV 1080i to 4:3 NTSC on Export
  • Down converting HDV 1080i to 4:3 NTSC on Export
    Posted by Warren Davis on August 30, 2008 at 1:50 am
    Hey…
    I am working on some footage for my church and I shot everything in HDV 1080i60 and have edited it as such with a 16:9 aspect ratio. My church’s video system is SD with a 4:3 aspect ratio. It will play my file but it squishes it and the project just doesn’t look good. I am wondering how to down convert and letterbox my project so that it displays correctly at 4:3 SD. Is there an option in the export menu that would allow me to letterbox my project so it will look right since my final destination for this file is a 4:3 SD video projection system? This may be a dumb question but any help is appreciated!
    Warren
    Joe Langenfeld replied 18 years, 1 month ago 3 Members · 2 Replies
  • Shane Hunter
    August 30, 2008 at 5:22 am
    Yay for anamorphic.
    https://www.geniusdv.com/weblog/archives/169_in_final_cut_pro.php
    That should answer your question.
  • Joe Langenfeld
    August 30, 2008 at 1:58 pm
    The best quality that I have found for a 4×3 downconvert from HDV is to output the HDV sequence back to tape, and then set the deck for 4×3 crop. This looks better than the software only solution. But I believe that only the deck has the 4×3 option… the camera may only have letterbox or squeezed.
