Activity Forums AJA Video Systems down-convert on Kona LH
  • down-convert on Kona LH
    Posted by Jason Pachomski on August 27, 2006 at 8:16 pm
    Hello all,
    My first venture onto the Kona messageboard … looking for some suggestions from the experts…
    We’re cutting an HD project that was pulled into FCP at DVCPROHD. Our sequences are at 23.98. I need to pump the sequence out through a KONA LH to DigiBeta and I want to aspect ratio to stay 16×9.
    My question is, will the Kona downconvert to SD AND do the reverse-pulldown to make it 720×480 @ 29.97? If so, are there pitfalls I should look out for?
    Thanks in advance.
    Walter Biscardi replied 20 years, 1 month ago 2 Members · 1 Reply
  • Walter Biscardi
    August 27, 2006 at 8:28 pm
    You can adjust the pulldown patter in the Kona control panel if you have any problems.
    When we cut some episodes in 23.98 I had no issues laying the shows off to DVCAM for reference copies.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
