Activity Forums AJA Video Systems Down Convert DVCPRO-HD 720p to Mini DV/DSR-11 through Kona
  • Down Convert DVCPRO-HD 720p to Mini DV/DSR-11 through Kona
    Posted by Pierre on June 28, 2007 at 2:43 am
    I’m trying to take HVX-200 footage (which is currently in FCP sequence) and lay it off to DV/DSR-11 through my Kona 3.
    Can’t get it right. There is only a component out on the kona and only a standard RCA (yellow, red, white) on the DSR 11. So if I hook the Y/G/CVBS from the Kona up to the Yellow RCA on the DSR-11 all I get is the picture in black and white.
    What am I doing wrong?
    help please
    John Pale replied 19 years, 3 months ago 3 Members · 3 Replies
  • John Pale
    June 28, 2007 at 6:15 am
    Your deck doesnt have component connections.
    It does, however, have S-video. The Kona can output s-video, but you need to buy a special BNC to S-video adapter cable.
    https://www.kramerelectronics.com/cables/item.asp?desc=14
  • Gary Adcock
    June 28, 2007 at 1:01 pm
    [John Pale] “The Kona can output s-video, but you need to buy a special BNC to S-video adapter cable.”
    why not just have the Kona output Composite video?
    you can set the analog to composite video and then use the “Y/G/” connection for the video into to your DSR 11
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • John Pale
    June 28, 2007 at 2:25 pm
    What Gary suggests is easier and cheaper, but S-Video will give you a slightly sharper image.
    If you are unhappy with the quality…think about getting the cable, its not terribly expensive.
