Activity › Forums › Apple Final Cut Pro Legacy › Down conversion from HD (720P) to 720X480 letterbox
Posted by Pierre Tremblay on July 5, 2007 at 4:21 pmHi there,
I’m finishing a project shot and edited in 720P. I want to export an .m2v in SD (720X480) in letterbox (black bands at the top and bottom) to burn to DVD. My Kona 2 card does it on the fly to my broadcast monitor BUT how can I capture this signal? If I export from my sequence I get either an anamorphic clip or a streched one, no black bars. I’m trying to avoid to sent it to my deck (DVCam-DSR-1500) and recapture it. What is the proper way to finish this??
Thanks.
Pierre Tremblay
FCP 5.1.4
Kona2
OSX.4.10Dean Kuhnlein replied 18 years, 7 months ago 11 Members · 20 Replies -
Shane Ross
July 5, 2007 at 4:26 pmJust use Compressor. That’s what I do. It’ll Compress the 720p down to 720×486 with black bars just fine.
Shane
Littlefrog Post
http://www.lfhd.net -
David Roth weiss
July 5, 2007 at 4:37 pm[Shane Ross] “Just use Compressor. That’s what I do. It’ll Compress the 720p down to 720×486 with black bars just fine.”
Shane,
As I’m sure you know, the proper dimensions for DVDs are 720×480, not 486. Probably caffiene related.
David
“No job is worth doing more than once…”
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
Shane Ross
July 5, 2007 at 4:46 pm[David Roth Weiss] “As I’m sure you know, the proper dimensions for DVDs are 720×480, not 486. Probably caffiene related.”
Really? How can this be? SD is 720×486…always has been. DV introduced the 720×480 dimensions.
SO you are telling me that the DVD of CASINO ROYALE I have is 720×480? Why? and why would DVD SP format to 720×480 when standard def dimensions are 486?
Shane
Littlefrog Post
Pierre Tremblay
July 5, 2007 at 4:46 pmWell, that’s what I did and didn’t get the letterbox “boxes” on the file, just an anamorphic
file. I looked at all the Compressor settings and didn’t find where to select for a letterbox
compression.Pierre
Shane Ross
July 5, 2007 at 4:48 pmCOmpressor doesn’t have the 16:9 setting. DVD SP has that. THAT is where you tell it to letterbox the footage.
Shane
Littlefrog Post
David Roth weiss
July 5, 2007 at 5:08 pmShan[Shane Ross] “SO you are telling me that the DVD of CASINO ROYALE I have is 720×480? Why? and why would DVD SP format to 720×480 when standard def dimensions are 486?”
The DVD spec is 720×480 for NTSC. I didn’t write it personally.
FYI, here are all the file sizes that conform to the DVD spec.
Coded frame sizes:
525/60: 720×480, 704×480, 352×480, 352×240
625/50: 720×576, 704×576, 352×576, 352×288David
David Roth Weiss
Los Angeles -
Pierre Tremblay
July 5, 2007 at 5:13 pmThanks Shane,
DVD SP worked, it was the last missing link.
Pierre
Michael Hendrix
July 5, 2007 at 5:32 pmThe 720X480 spec was introduced for DV and stuck with DVD production. With what little I know, 486 is not divisible by 4, 480 is which is the colorspace DV works in. Digital color sampling works in 4 pixel increments, i.e. 4:2:2, etc.
Someone else is welcome to chime in because that is about as much as I understand.
David Roth weiss
July 5, 2007 at 5:35 pm[Pierre Tremblay] “Well, that’s what I did and didn’t get the letterbox “boxes” on the file, just an anamorphic
compression.”Pierre,
In the future, just so you know, if you encode widescreen in Compressor and author in DVDSP and it will create a DVD that automatically displays 4×3 letterboxed on SD TVs and 16×9 on widescreen TVs.
David
David Roth Weiss
Los Angeles -
Tom Brooks
July 5, 2007 at 5:55 pmIt has more to do with the macroblock structure of the codec. MPEG-2 frame sizes should be evenly divisible by 16. That’s for encoding and decoding efficiency. Then you have the allowable frame sizes in the DVD spec on top of that. Ben Waggoner’s book on comression (Compression for Great Digital Video) has some pretty good info on this in layman’s terms.
