Activity › Forums › Apple Final Cut Pro Legacy › Down conversion from HD (720P) to 720X480 letterbox
Dean Kuhnlein replied 18 years, 7 months ago 11 Members · 20 Replies
Chris Borjis
July 5, 2007 at 6:24 pmthere is an anamorphic setting in compressor to flag
the stream 16:9Also, I prefer quicktime conversion for any down conversion HD to SD, it does a much better job resizing than compressor can on its best settings.
It also allows you to letterbox non-anamorphic to SD which is perfect for making broadcast dubs since the stations don’t usually take or want anamorphic dubs.
Gary Adcock
July 5, 2007 at 7:57 pm“[David Roth Weiss] “As I’m sure you know, the proper dimensions for DVDs are 720×480, not 486. Probably caffiene related.”
shane Really? How can this be? SD is 720×486…always has been. DV introduced the 720×480 dimensions. “All NTSC mpeg content is 720×480
even the over the air content.gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Shane Ross
July 5, 2007 at 8:43 pm -
Seawild
July 5, 2007 at 9:03 pmHi Folks,
What would be the resize(scale?) setting if I wanted to drop a 16×9 in a 4×3 timeline and letterbox.
Chris -
Chris Borjis
July 5, 2007 at 9:51 pmit should do that automatically just like still images do.
import your 16×9 footage, make a new 4×3 sequence
check the anamorphic box in the settings for the 16×9
clip then drop it in the 4×3 sequence. -
Seawild
July 5, 2007 at 10:23 pmThanks!
But, I’m dropping a 16×9/Full Frame/1.78 sequence into a 4×3 sequence.
I would like the 4×3 sequence to be 1.78 letterboxed(top&bottom) but when I drop it in, it shows 4×3/full frame/anamorphic(i think).
I’m just wondering what the numbers are to scale it and perserve the original aspect ratio…
Chris -
Alexander Kallas
July 6, 2007 at 3:38 am[gary adcock] ”
shane Really? How can this be? SD is 720×486…always has been. DV introduced the 720×480 dimensions. ”All NTSC mpeg content is 720×480
even the over the air content.”When Compressor is fed a 720×486 file to transcode to mpeg2, it automatically crops lines off the top and bottom to create the 720×480 mpeg2 file
Cheers
Alexander -
Chris Borjis
July 6, 2007 at 4:25 amIt should be doing just that.
have you right clicked your clip and gone into the
settings and marked it as anamorphic? -
Lewwwws
July 11, 2007 at 1:12 amhi, just noticed this post while browsing. I dont use apple, I use liquid and it seems some contradictory info from the mods at Avid.
They say that Liquid’s 720×486 (which is as close to 720×480 as Liquid gets) supports all national standard of NTSC. But if I am outputting to DVD, which is 720×486, am I really getting a quality reduction with Liquid? -
Dean Kuhnlein
February 7, 2008 at 2:52 amDavid, would you walk me through the process? I have been converting my HD timeline to DV/DVCPro 50 NTSC and inputing into a 4×3 timeline with a -33.33 resize. I then output via compressor to an M2V. Is this wrong. Could I drop a step in this process and lean on DVD SP to do the letterboxing for me?
I seem to get a good deal of moire and I am trying to avoid this. The footage was shot on a Panasonic HDX900 960/720 24p.
Thanks for your help.
dkDrive Right. Pass Left.
