Activity Forums Adobe After Effects Doubt Animating a path
  • Doubt Animating a path
    Posted by Ezequiel Zybert on August 15, 2021 at 7:57 pm
    Hello. I have a path, a line with 3 vertices. I animated its vertices like the file attached shows.
    Keyframe 1, straight line.
    Keyframe 2, left vertex up
    Keyframe 3, mid vertex up
    Now I need what the image attached shows in the right column. To modify the keyframe 3 moving up the right vertex, but the important thing is that I need it to start moving from keyframe 1, not from the 2nd. Is there a way to do it?
    Thank you
    Ezequiel Zybert replied 5 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
