Activity Forums Apple Final Cut Pro Legacy double system sync
  • double system sync
    Posted by Jim Curtis on May 24, 2011 at 4:32 pm
    I’m cutting using double system sync. Video is from a 5D; audio is from a Zoom recorder.
    After syncing, is there a way to lock the double system tracks in sync with the video?
    The Modify > Mark In Sync command isn’t doing it.
    I don’t want to Nest because I need access to the discrete audio tracks.
    I take it that this feature will be in FCP X, but I need it now. Am I SOL?
    Jim Curtis
    jamesphilipcurtis.com
    MacPro (Harpertown-Early 2008) 2×4 3GHz; 32G RAM all the same brand; 10.6.3; QT 7.6.6; FCS3; Kona LHi in PCI slot 3 (8.1.1); Primary display: 30″ ACD; Monitoring: Kona LHi SDI to AJA HDP2 converter to HDMI on the HP DreamColor.
    John Pale replied 15 years, 4 months ago 2 Members · 3 Replies
  • John Pale
    May 24, 2011 at 4:50 pm
    Look up Merge Clip in the Help files
  • Jim Curtis
    May 24, 2011 at 5:10 pm
    Merge Clips isn’t working for some reason, but Link Clips is, and that’s actually what I wanted to do. I must have had a brain lapse. I know about Link Clips, but I guess I was thinking that it only worked for AV clips that had the audio and video together, and it was a method of unlinking them.
    Anyway… thanks for your reply, John. It jump-started me where coffee did not.
  • John Pale
    May 24, 2011 at 5:38 pm
    Merge clip does not work in the timeline. You do it in the Browser and Viewer.
