Activity › Forums › VEGAS Pro › Dolby Digital AC-3 Pro vs Sony Wave 64 (*.w64)
  • Dolby Digital AC-3 Pro vs Sony Wave 64 (*.w64)
    Posted by Jim Prisby on March 31, 2015 at 3:17 pm
    For all of my past SD projects I always rendered the audio using Dolby Digital AC-3 Pro but now that I’m learning about rendering HD projects I find some people recommending rendering the audio using Sony Wave 64. Which is considered better for HD audio and why?
    Thanks for your reply,
    Jim
    Intel 2.67GHz Core2 Quad CPU.
    8 GB RAM
    NVIDIA GForce GTX 570 superclocked
    Windows 7 64bit
    Jim Prisby replied 11 years, 6 months ago 2 Members · 2 Replies
  • Aaron Star
    April 1, 2015 at 8:13 am
    https://www.custcenter.com/app/answers/detail/a_id/918/~/what-is-wave64%3F
    It was just the way they address the container, so that you can have a very large file size. The recording format you put inside it is what matters. When you can record 192Khz@24bits, the file sizes climb fast.
    AC3 is a delivery format specializing in compression, multi-track delivery, and tops out at 48Khz sample rate. Basically just another audio format that specifically licensed by Dolby Labs, mainly marketing designed to ride on THX and theater sound format PR.
    Unless you are referring to 32FP or 64FP(double precision) audio. With Floating Point Audio in .w64, you get 32 channels, and the audio is written in a format that does not have the range limits that 16-24bit audio does.
    https://en.wikipedia.org/wiki/Audio_bit_depth
  • Jim Prisby
    April 2, 2015 at 2:47 am
    Thanks, Aaron, for the explanation. Looks like I’ll be sticking with DD AC-3 Pro.
    Jim
    8 GB RAM
    Windows 7 64bit
