Dolby 5.1 Surround Sound
I am having difficulty creating a Dolby 5.1 Surround Sound Master DVD. I read the manuals for FCP, Compressor and DSP and I can’t seem to get it to work. Does anyone have any experiance doing this that can hep? My work flow is as follows:
I receive 6 WAV files from my audio engineer which were created with ProTools and labeled according to proper 5.1 surround sound placement, (C, L, LF, LS, R, RS) I import the files seperately into FCP6 and after I am done editing I export to Compressor. I drag the Dolby digital Pro 5.1 compression setting into the batch window. It is suppose to seperate the labeled files automatically. ( Their doesn’t seem to be a way to confirm this step until you are done) I then import the AC3 file that Compressor creates into DVD Studio Pro. (It still seems that I am not able to confirm I am working with the proper 6 channels – it appears as a single AC3 file.) I then build and burn a DVD only to find out when I play it thru a surround sound system that even though it reads as a Dolby 5.1 surround sound file. It is actually only playing stereo. Any ideas?
