Activity › Forums › Maxon Cinema 4D › doing dynamics follow a path
  • Adam Trachtenberg
    April 2, 2014 at 3:40 pm
    It’s possible to mix mograph or thinking particles with physical simulation, but the more you blend out the simulation the less it looks like a simulation. Best bet might be to build a trough or tube to guide the cube and then make it invisible to the render engine.
  • Victor Camacho guerrero
    April 3, 2014 at 10:25 am
    Thanks Adam,
    pretty interesting trick you showed me there. As you said the simulation gets quite lost so, in the end I did manually the animation by hand ( quite painful) but it works too.
    thanks so much
