Activity Forums Apple Final Cut Pro Legacy Does your FCPS2.0 volume serial upgrades make any sense ??
  • Does your FCPS2.0 volume serial upgrades make any sense ??
    Posted by Anders Haavie on June 13, 2007 at 12:01 pm
    We have a couple of different volume serials for the finalcut studio 2.0. 1 serial is for 8 clients, another one is for 2 etc etc. (bought at different times, thats why). When I receive my volume serial upgrade serial, it doesn’t say for how many clients the upgrade serialnumbers works for. Anyone else experienced this ?? I guess I can try out the different serials, but that’s a bit of a hazzle.
    Anders
    Jerry Hofmann replied 19 years, 2 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    June 13, 2007 at 12:11 pm
    With multiple licenses, I’m sure it’s just one serial number for each purchase. Might call Apple if this is some sort of problem.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Anders Haavie
    June 13, 2007 at 5:30 pm
    Right, but I have received 3 different packages with one serial which should cover 8 users, the others should be used on two clients each. .so how do I know which one is the one for 8 users.
  • Jerry Hofmann
    June 14, 2007 at 12:57 am
    Good question… Might Call Apple… but I’ll bet if you keep each system you install running, you’ll get some sort of error when you try to install one more than the serial number you’re using covers.
    Jerry
