Activity Forums VEGAS Pro Does Sony Vegas Pro 9.0 need just the .veg file to work?
  • Does Sony Vegas Pro 9.0 need just the .veg file to work?
    Posted by Zena Craven on August 29, 2010 at 6:22 am
    I had been using the trail version of Sony Vegas Pro 9.0 and since the trail has now run out, uninstalled the trail version and installed the full Sony Vegas Pro 9.0. I had moved the .veg file I had been using/saving to another folder and tried opening it up (from that same folder) with Sony Vegas Pro 9.0 and it loads to 14% before crashing and giving me this error: “An error occurred while loading the project whatever. veg. An error occurred while reading the file. Make sure you have read to the file/folder and that it is not corrupted.” Does the 32/64 bit matter? I do believe the trail version was 32 bits and the full version I have now is 32-64 bits. I can’t see that being an issue, but as I’m not sure what’s going on, I figured I’d mention everything I know/have noticed. Regardless, isn’t the .veg file all I need (maybe besides the videos I had used to make the edited video, which I still do have) to have it work/load on Sony Vegas Pro 9.0?
    Dave Lozinski replied 15 years ago 2 Members · 1 Reply
  • Dave Lozinski
    August 24, 2011 at 12:52 am
    Yes, the .veg file should be all that you need. If it can’t find the audio/video files contained within the project, it should pop up error messages during loading saying something to the effect of it cannot find xyz media file.
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
