Does sequence pixel size in PP matter for a bigger export?
This week i made my first timelapse in Premiere pro 5.5 on a Mac.
I made it 1620×1080 to keep the 3:2 photo ratio, and to play it as big as possible on HD players (with 2 small black strokes at the side).
For this project i kept the imported photo’s at it’s original size (5616×3744 or some copped a little in 3:2 without extrapolation) because i wanted to use some Ken burns effect.
In the end i exported the sequence as a QT mov with Prores 422HQ codec. It looks great for shapness, although QT plays it too bright with not enough saturation. This is another question than the one i wanted to post, but solutions are welcome (i can’t find anything about profiles or gamma in PP or QT, and it’s made on a mac for a mac, so why would there be gamma shift or something like that)?My question:
If i do another export with a higher resolution (for instance my monitor resolution 2400×1600, or even higher in future when new projectors / tv’s with higher resolution than HD arrive) does PP take my original (even much bigger) jpgs, and scales it to the new resolution, or does the sequence setting have any influence, does it interpolate a 1620×1080 to something bigger again (but smaller than the original jpgs).
So.. does the sequence setting matter in terms of quality (or other things), and do i need to make a new sequence first with the right resolution, and copy paste my timeline?
I hope not, because of all the scaling, positioning (Ken burns) etc. Or is there a trick?
How do you handle this “future proof” issue? Or is it no issue? I can understand that with film the luxury of this much pixels is not that common.It’s all the same aspect ratio (3:2) if that matters, and the rest of the settings is also the same.
I hope someone can help.
Thanks.
(sorry for my English, i’m from The Netherlands)
