Activity Forums Apple Final Cut Pro Legacy Does Qmaster work?
  • Does Qmaster work?
    Posted by Jeffrey Burns on August 11, 2009 at 8:28 pm
    Has anyone ever been successful in getting Qmaster to work with compressor?
    I’ve tried everything!
    I need to render out a lot of green screen work and would love to speed it up. I want to create new .mov files with an alpha channel.
    Jeff Franklin replied 16 years, 10 months ago 4 Members · 4 Replies
  • Mark Raudonis
    August 11, 2009 at 8:41 pm
    Yes. We use it everyday to harness 50+ computers.
    When you say “render out green screen” what program do you mean? FCP? AE? what?
    Some can take advantage of distributed rendering, some can’t. You need to know if the program
    you’re using will enable distributed rendering. Read the manual.
    Mark
  • Jeffrey Burns
    August 12, 2009 at 1:30 pm
    Well I have read the Qmaster online manual and researched on google and apple sites. I am rendering out from Final Cut (This is the Final Cut Forum!)
    Compressor Log shows error: Processing service request error: Final Cut generated an error or unexpectedly quit.
    Compressor works fine if “This Computer” is selected as the cluster, it fails when the QuickCluster is selected.
    I am using a test sequence that has 10 seconds of color bars with no effects. I use “Send to Compressor” to start export. Selected a default preset (h.264 for apple TV). Selected the Cluster (EditA) with include managed computers on other computers not selected.
    I have three G5 2×3 GHz Dual Core Intel Xeon with 8 GB 677MHz DDR2 Memory hooked up to a 12 TB xSan. OSX 10.5.8 with all current updates.
    All three systems are identical.
    Same software – Final Cut 7.0, Compressor 3.5, Qmaster 3, Quicktime 7.6.2
    Qmaster settings:
    Share this computer as – QuickCluster with services
    Services – Sharing set for Compressor and Rendering
    Managed not set for Compressor and Rendering
    Running two instances
    QuickCluster: Idenify this QuickCluster set to EditA
    Include unmanaged services from other computer not checked (tried checked also)
    No Security set.
    Cluster Storage set to /Volumes/xSan/Qmaster/EditA (permissions set with ACL with Full control. All systems can read/write/create with no problem.
    Network – Allow discovery via Bonjour is checked
    Use network interface is set to Ethernet 1 on all systems
    I’ve rebooted computer, reset and restarted Qmaster.
    I’ve also setup a “Managed Cluster” using Qadministrator with no luck also.
    Once I can get the simple output working I’d like to be able render out sequences that have Primatte keys.
  • Martin Baker
    August 13, 2009 at 6:43 am
  • Jeff Franklin
    October 14, 2009 at 8:07 pm
    “Does Qmaster work?”
    I would say only when it feels like it.
