Activity › Forums › Apple Final Cut Pro › Does proxy/original preference affect sharing/send to compressor?
Posted by David Powell on April 24, 2013 at 6:37 amThe title says it all. Do I have to switch back to Original before sending to compressor?
Jason Brown replied 13 years, 5 months ago 4 Members · 3 Replies -
Nikolas Bäurle
April 24, 2013 at 11:25 amYes. If you stay in Proxy it will render a Proxy.
“Always look on the bright side of life” – Monty Python
Mathieu Ghekiere
April 24, 2013 at 12:51 pmIf you are in Proxy Mode, and share from FCPX straight, it will render out as Proxy.
Not sure if this is also the case when sending to Compressor… I would guess not, but I could be wrong.
Jason Brown
April 24, 2013 at 4:54 pmI like how easy it is to switch between proxy and how it is global, but I’d really like some kind of dialogue telling you when you share a “master file” that you are doing so in proxy mode. I’ve sent out final master flattened prores many times at proxy without intending to. There should be a dialogue that you can turn off if you want to.
