Activity Forums VEGAS Pro Does projects saved in Vegas 11 not open up in Vegas 9?!!
  • Does projects saved in Vegas 11 not open up in Vegas 9?!!
    Posted by Ro Ghosh on February 1, 2012 at 6:29 pm
    I have a project that I have edited and saved on Vegas 11 but I am using a flash drive and using a different computer that has Sony Vegas 9 but the .veg file will not open (in 9). Is that true? Is there a way around it? Thanks in advance
    John Rofrano replied 14 years, 7 months ago 3 Members · 2 Replies
  • Mary Waitrovich
    February 1, 2012 at 9:50 pm
    There is no way around this. You can open projects saved in earlier versions in later versions, but not vice versa. Sorry.
    Mary Waitrovich
    Media Plus You, LCC
    http://www.mediaplusyou.com
  • John Rofrano
    February 1, 2012 at 10:50 pm
    The only way around it is to have Vegas Pro 11.0 and 9.0 open on the same system and cut and paste between the two but even then you will loose track FX and other things. As Mary said, there is backward compatibility in newer versions for opening older files but older versions of Vegas cannot open newer files.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
