Activity Forums Maxon Cinema 4D Does Override Group (Take system) work with polygon selections?
  • Does Override Group (Take system) work with polygon selections?
    Posted by John Willard on April 19, 2016 at 3:58 pm
    With the Take system you can create override groups so that you can change the material for multiple objects at once. However, what if an object has two material tags, whereby one of them is linked to a polygon selection. It seems override groups does not work in this case since it changes ALL material tags of the object to the same material, is this correct?
    John Willard replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
