Activity › Forums › Apple Motion › does motion2 have an AE “sequence layers” style option?
Posted by Reneon on August 14, 2005 at 6:25 pma way to automatically shift layers in defined sequence order (with transition options) similar to the keyframe assistant>sequence layers in AE?
thanks
Rene
Scott Barnes replied 13 years ago 3 Members · 3 Replies -
Mark Spencer
August 15, 2005 at 1:11 amYes it does – so did Motion 1, btw. Just select all your objects in the File Browser, drag them to the Canvas, but don’t release the mouse – you’ll see options to either edit them in by compositing or sequential.
Note and feature request: you can’t add any overlap to the Sequential option, would be nice to build in overlap to fade between stills, for example
Mark Spencer
Freelance Editor/Producer
Apple-certified instructor, Final Cut Pro and Motion
Author, Motion Visual Quickstart Guide from Peachpit Press (coming soon)
https://www.applemotion.net -
Reneon
August 15, 2005 at 12:26 pmThanks Mark.
The overlap is an integral part, let’s hope Apple add it.
Scott Barnes
September 18, 2013 at 2:05 amI was wondering if this same effect could be done with items that are already in the project or created inside motion. For example I have a bunch of text layers all a single frame that I now need to sequence them out but I don’t have the option of dragging them in from the file browser.
I am not bound by what is possible.
