Activity › Forums › Media 100 › Does Media 100 make AE run in YUV instead of RGB?
  • Does Media 100 make AE run in YUV instead of RGB?
    Posted by Bob Flood on May 18, 2007 at 8:35 pm
    Hi
    I am also crossposting this in the AE forum
    I used to use Media 100 a long time ago (version5?) and I remember claims of “native YUV color space” within the application, which was true.
    BUT
    If you had after effects on the same machine as M100 hardware, didnt AE work in YUV space as well, instead of the AE native RGB?
    thanx
    bee eph
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Bob Flood replied 19 years, 4 months ago 2 Members · 2 Replies
  • Floh Peters
    May 18, 2007 at 9:46 pm
    From what I understand, Media 100s hardware works in YUV, and the incoming files get stored as YUV files (e.g. in the Media 100 i codec). If these YUV files are accessed via QuickTime, like in AE or QuickTime player, they are converted into RGBA. All processing in AE happens in RGB colorspace before the files get written back into the Media 100 i (YUV) codec.
    Some older hardware (including the first AVID systems with the pre-Meridien boards) worked in RGB, which made a conversion from the incoming YUV signals to RGB and back to YUV for output necessary. Most of todays hardware is YUV, though.
  • Bob Flood
    May 22, 2007 at 1:36 pm
    Floh
    thanx! i was not sure about format conversion, as it has been a few summers since i ran M100
    bee eph
    Bob Flood
