Activity Forums Maxon Cinema 4D does lathe have to be off the world axis?
  • does lathe have to be off the world axis?
    Posted by Chad Demoss on February 14, 2018 at 10:46 pm
    I was trying to lathe something and there was a hole at the bottom every time and I searched (googled) around and found that you need to lathe around the 0 position on the y axis (or the 0 position of any axis I assume). Isn’t there a way to lathe around an objects own center point?
    Chad Demoss replied 8 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    February 15, 2018 at 12:11 am
    The lathe axis is determined by the location of the lathe object. By default it’s created at world center, but you can move it anywhere you like.
  • Chad Demoss
    February 16, 2018 at 5:20 pm
    thanks adam.
    something wonky going on when I move the lathe object or axis, ill just stick to making everything on the world center.
