Activity Forums AJA Video Systems Does Kona Read FCP6 Sequence Timecode?
  • Does Kona Read FCP6 Sequence Timecode?
    Posted by Russell Lasson on April 1, 2008 at 7:03 pm
    Will the Kona cards read the timecode from a FCP6 sequence while playing back in FCP? If so, does that allow it to do a timecode window burn on output?
    My Kona LH card is on a FCP5 system so I can’t test it.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
    Russell Lasson replied 18 years, 5 months ago 2 Members · 2 Replies
  • Gary Adcock
    April 1, 2008 at 8:36 pm
    [Russell Lasson] “Will the Kona cards read the timecode from a FCP6 sequence while playing back in FCP? If so, does that allow it to do a timecode window burn on output? “
    Russell
    use the Timecode Settings in the Kona Control Panel….
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Russell Lasson
    April 1, 2008 at 9:42 pm
    Thanks Gary.
    I gave it a shot starting up from a start-up disk that had FCP6 and sure enough it worked. But when I go back to FCP5.1 on that system, it doesn’t work any more:(
    But now I know that it works and that’s great!
    -Russ
    Russell Lasson
    Provo, UT
