Activity › Forums › Apple Final Cut Pro › Does Every Project Really Have To Load Before I Can View The Project List?
Jonas Bengtsson replied 14 years, 11 months ago 7 Members · 13 Replies
Dave Brandt
October 11, 2011 at 1:16 pmHi Kevin,
I wasn’t aware that the images don’t shrink. To be honest the situation hasn’t come up as I usually don’t delete anything from the client image. I guess in the old days I used to delete captured footage and archive to tape but those days are long gone now.
I usually just drag the image from the work drive to the backup drive. I don’t create a new image, but if i wanted to shrink that would be the way.
as far as mounting I just double click the image in the finder, and to unmount i eject just like a cd or any other installer image etc.
hope that helps
db
Dave Brandt
October 11, 2011 at 1:21 pmJust found that you can compact a sparse image using terminal
“Similarly, a .sparseimage file that has expanded in size but then had files deleted, can be “compacted” to a smaller size with the following command:
hdiutil compact MyFile.sparseimage”from https://en.wikipedia.org/wiki/Sparse_image
db
Jonas Bengtsson
October 12, 2011 at 7:29 amIs this problem reallated to my problem that sometimes when you in Event Library scroll, scimming och chose a clipp, it can take ages for the action to apper in the viewer.
So if I wait about very long time after started FCP X.
Scimming and other actions will be incredibla fast.
