Activity › Forums › Apple Final Cut Pro › Does Every Project Really Have To Load Before I Can View The Project List?
Posted by Philip Davies on October 10, 2011 at 3:58 pmI have about 25 projects and 10 events belonging to the same client on an external hard drive.
Because FC seems to insist on loading every project when I view the projects list, it’s now taking forever (ok, a good 5mins) before I can get to the only project I actually want to work on.
Even more annoyingly, there’s now a severe lag when scrolling through the project list. I’m using a powerful 3.4GHZ quad core iMac so God help me on my Macbook!
Is this a common complaint or am I missing something obvious?
Jonas Bengtsson replied 14 years, 11 months ago 7 Members · 13 Replies -
Steve Connor
October 10, 2011 at 4:10 pmhttps://assistedediting.intelligentassistance.com/EventManagerX/
This is what I use, it works perfectly.
“My Name is Steve and I’m an FCPX user”
Kevin Patrick
October 10, 2011 at 9:01 pmIt appears that this application moves Events and Projects in and out of the FCP X Event/Project folders. As opposed to you doing it yourself at the Finder level. Or am I missing some additional capabilities?
Steve, I was wondering if you tried, or looked at Steve Martin’s suggestion of managing FCP X Events/Projects with Disk Images?
https://www.kenstone.net/fcp_homepage/fcp_x_managing_disk_image_martin.html
Seemed like an interesting idea when I first read about it. But I have yet to try it. Outside of guessing (correctly) how much disk space you will need, I’m not sure what other downsides would be. Mounting and Unmounting seems simply enough. Quicker than copying, if you don’t have media inside your Event folders.
Steve Connor
October 10, 2011 at 9:46 pm[Kevin Patrick] “It appears that this application moves Events and Projects in and out of the FCP X Event/Project folders. As opposed to you doing it yourself at the Finder level. Or am I missing some additional capabilities?
“It does simply give you a quick graphic UI that results in your folders being moved, it’s a bit of functionality that should be in FCPX. You can move manually but IMHO the app makes it easier to keep track of what is where.
Haven’t tried the disk image idea yet.
Mark Morache
October 11, 2011 at 1:29 amThis really annoys the crap out of me as well. I can’t believe Apple would make this “all the media and projects all the time” the paradigm if our wait time keeps getting longer as the projects start piling up. Hiding things in finder is an easy enough workaround, but why not design it correctly to begin with?
$5 for an app to help with this seems like money well spent. But it’s still a workaround. Yikes.
FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.Mark Morache
Avid/Xpri/FCP7/FCX
Evening Magazine,Seattle, WA
https://fcpx.wordpress.com -
Dave Brandt
October 11, 2011 at 8:07 amHi,
I use sparse images for all my clients. you can specify the size to be as big as the hard drive they reside on, but the great thing about sparse images is that they only use up as much space as the data inside them. I have around 20 disk images on my 2TB raid and there is plenty of space for more.
The great thing about images is that I have everything belonging to that client on this image. Graphics, text files, review notes etc etc. It is a very tidy way of working, and makes backup and sharing a breeze.
just try it out, create sparse image in disk utility, specify the size as big as you want. if you specify larger than the hard drive capacity it will be ok until the image grows too large in which case you will be asked to move it to a larger disk.db
Jason Jenkins
October 11, 2011 at 10:21 am[Dave Brandt] “I use sparse images for all my clients. you can specify the size to be as big as the hard drive they reside on, but the great thing about sparse images is that they only use up as much space as the data inside them. I have around 20 disk images on my 2TB raid and there is plenty of space for more.
just try it out, create sparse image in disk utility, specify the size as big as you want. if you specify larger than the hard drive capacity it will be ok until the image grows too large in which case you will be asked to move it to a larger disk.”Dave, thanks for sharing. This sounds like a great way of working! Do the disk images mount automatically or do you manually mount the one you want to work from?
Jason Jenkins
Flowmotion Media
Video production… with style! -
Jason Jenkins
October 11, 2011 at 11:22 am[Dave Brandt] “I manually mount. It’s just a double click away”
That’s good to know. I’m using separate drives for clients right now, but I’m looking at getting a Thunderbolt RAID and this looks like the perfect system to “control” the projects.
Jason Jenkins
Flowmotion Media
Kevin Patrick
October 11, 2011 at 1:01 pmDave,
I understand that it grows in size as you add to it, but it won’t shrink if you delete files. But, I was wondering how you back it up. Do you create a new DI on an archive drive and them copy? Allowing you to shrink the DI, if you’ve removed a significant amount of files?
How do you mount and unmout? With Disk Utilities?
Thanks for the feedback. Steve Martin’s idea of using DI seemed like a pretty nice work flow. But I’ve never used DIs before, so it good to hear it’s working for someone.
