Activity › Forums › Apple Final Cut Pro Legacy › does dvdsp recognize 16:9 footage?
  • Walter Biscardi
    January 16, 2006 at 10:00 pm
    If you export a 16:9 project from FCP it should show up as 16:9 in DVD Studio Pro. That’s how I exported my film earlier this month and then I set up DVD SP as a 16:9 project. My movie plays full screen on an HDTV monitor and in Letterbox on an SD monitor automatically.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Jonathan Hanneman
    January 16, 2006 at 11:16 pm
    If you’re working with anamorphic footage and you’ve exported correctly, make sure your DVDSP track is set to 16:9 letterbox instead of 4:3. If you click on the track icon in the upper left window (default setup), the 16:9 option should become available in a window on the lower right.
    Jonathan
