Activity › Forums › Adobe After Effects › Does anyone know this plug in?
  • Does anyone know this plug in?
    Posted by Seth Albee on February 10, 2022 at 5:18 pm
    I came across a great plug in a few months ago… and now I can’t for the life of me track it down. You can select multiple layers with multiple keyframes and automatically create a control layer with just two keyframes that allows you to adjusts the timing of all bound keyframes (as if you highlighted all and held the alt key and dragged.) I know that pre-comping and simply adjusting the time remapping would achieve the same thing, however in some instances you don’t want to always pre-comp the layers. Does anyone know the name of this plugin?
    Andy Engelkemier replied 4 years, 7 months ago 2 Members · 1 Reply
  • Andy Engelkemier
    February 11, 2022 at 1:22 pm
    That sounds like part of Motion V2 called Animo. There are a lot of cool options in there. If you do much motion graphics in AE at all, it’s totally worth it. If you use illustrator much, I also highly recommend getting Overloard by battle axe? Not sure if I got the company right, but anyway it makes life much easier, and faster. Faster is always good.
    Motion V2 is worth it just for the really fast ability to control the speed of easing without having to manually adjust curves.
