Activity › Forums › Adobe After Effects › Does anyone actually use auto trace?
Malcolm Desoto replied 18 years, 3 months ago 6 Members · 13 Replies
Joey Foreman
June 14, 2008 at 2:09 amGet out that pen tool.
(Or you could give Mokey, not Mocha, a trial run. Imagineer offers excellent freelance discounts.)
Joey Foreman
Editor/Animator
Nowhere Productions, Athens, GA -
Darby Edelen
June 15, 2008 at 10:48 pmThe background you want to affect is primarily red, the foreground (the girl) has a lot of red in it as well, but the only place where the red is the primary component is in her face.
So if you can use Calculations and other effects to mostly isolate the background from the foreground (essentially a color difference key) you can then use a garbage matte to remove the areas of the foreground that are causing problems (her face and hands most likely). The color difference process should give you more detailed edges, but leave a lot of the foreground unmatted, which is where you can use roto to fix it.
Darby Edelen
Lead Designer
Left Coast Digital
Santa Cruz, CA -
Malcolm Desoto
June 16, 2008 at 3:34 pmThanks Darby
“The secret to creativity is knowing how to hide your sources.” –Albert Einstein
