Activity › Forums › Apple Final Cut Pro › DOA Project
  • DOA Project
    Posted by Eric Santiago on September 27, 2018 at 4:47 am
    I have a project (Library) that will not export via the Optimized/Original option.
    Its find under Proxy but not the high res version.
    This is the same project I was having Optical Flow Analysis issues with.
    To date, this project will crash constantly when I choose Optimized/Original in View mode.
    We were able to finish what we can under Proxy mode.
    The whole Library is now intact into the single package.
    Now the other issue is that under Proxy there are no missing file issues.
    But in the other mode, I get the yield badge and having a hell of a time finding the missing files since the app crashes at every move.
    I got to maybe three mouse clips before the beach ball comes up.
    There are no RETIMED clips in this project and I wish there was a Safe Mode option.
    I tried “REMOVE EFFECTS” and “DELETE GENERATED…” options in the past.
    None of these work.
    Again the PROXY mode seems to be fine.
    I would not want to supply a broadcaster that version 😛
    Eric Santiago replied 7 years, 11 months ago 4 Members · 27 Replies
  • 27 Replies
  • Jeff Kirkland
    September 27, 2018 at 6:28 am
    Have you tried creating a new library and copying the project over to there. If it’s stable long enough to let you do that, it’s something that often fixes corruptions.
    As far as the other goes, are you absolutely certain the original/optimised media is actually there? It sounds like the proxy is fine but the full resolution media is either missing or corrupted. I’ve certainly had projects crash because something has gone wrong with the original media files and I’ve had to restore them from a backup.
    Another thought might be to try sending the project XML to something like Worx4 X and letting it re-render all the original files and create a new library.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Jeremy Garchow
    September 27, 2018 at 11:11 am
    [Eric Santiago] “The whole Library is now intact into the single package.”
    Meaning everything is on one drive or the media is in the library and not external?
  • Eric Santiago
    September 27, 2018 at 12:02 pm
    [Jeff Kirkland] “Have you tried creating a new library and copying the project over to there. If it’s stable long enough to let you do that, it’s something that often fixes corruptions.”
    Yes, that I have done in so many different ways.
    I even as far as manually moving files via Finder as oppose to Consolidate.
    I have four versions of this project on four different drives.
    I thought I had it licked on the last drive but I forgot I had Proxy view on so it was all false.
    Jeremy at the start the files collected into separate folders above the package.
    Now I have them all in a package which leads to believe is futile.
    If something goes terribly wrong with that Library then the whole lot is f***.
    Also, Resolve is not letting it in via XML due to that.
    I might have to rebuild this project by copying all the media to a new drive then manually replace each one somehow since FCPX tends to try and correct itself once it knows its missing a file.
  • Eric Santiago
    September 27, 2018 at 12:05 pm
    [Jeff Kirkland] “Another thought might be to try sending the project XML to something like Worx4 X and letting it re-render all the original files and create a new library.”
    Jeff, I will look into this.
    Is it anything like XtoCC?
  • Eric Santiago
    September 27, 2018 at 5:49 pm
    [Jeff Kirkland] “nother thought might be to try sending the project XML to something like Worx4 X “
    Jeff do you know if the latest version works with RED media?
    Read an old article from fcp.co and it states it doesn’t.
  • Jeremy Garchow
    September 27, 2018 at 7:51 pm
    [Eric Santiago] “Jeff do you know if the latest version works with RED media?
    Read an old article from fcp.co and it states it doesn’t.”
    I don’t think it does, or MXF, or mp3, or many other formats. It’s too bad it doesn’t.
    I still don’t really know what’s going on with your Library.
    Obviously, there’s some really weird shit going on. It doesn’t seem right. I never keep media in the library. It’s just too limiting.
    When FCPX crashes, what warning does it give you?
  • Jeff Kirkland
    September 27, 2018 at 9:11 pm
    This all sounds really weird. You said the XML failed to import into Resolve – what was it’s problem with it?
  • Eric Santiago
    September 27, 2018 at 11:44 pm
    [Jeremy Garchow] “Obviously, there’s some really weird shit going on. It doesn’t seem right. I never keep media in the library. It’s just too limiting.
    Yea I’ve been using Library for Consolidate, my next move is to use a separate drive.
    No messages just the beach ball then when you check force kill, FCPX is not responding.
    Yes this is maddening and with Wor4x not working with RED, then Im pretty well out of ideas.
  • Eric Santiago
    September 27, 2018 at 11:46 pm
    [Jeff Kirkland] “This all sounds really weird. You said the XML failed to import into Resolve – what was it’s problem with it?”
    It comes up as an empty timeline.
    I believe its due to the Consolidate in Library causing it.
    I will extract the Original into an external drive and try that route.
  • Jeremy Garchow
    September 28, 2018 at 12:32 am
    When you force quit, you don’t get a pop up afterwords?
    You don’t have to use FCPX to move media out of the library, just right click on the library and “Show Package Contents” and copy the Event folders out of there.
Page 1 of 3
