Activity › Forums › Adobe After Effects › Do you know this effect or how to recreate it?
  • Erik Waluska
    August 3, 2013 at 2:28 am
    I’m not sure which effects you’re referring to but the ones that seemed to be used the most throughout the video Appeared to be the glitch, light leak, and RGB shift effects. You can do a search for those terms and it should pull up a lot of information. HTH
    Erik Waluska
    EAWmedia
  • Roland R. kahlenberg
    August 3, 2013 at 4:15 am
    The following thread is a good start to create RGB-shift effects – https://forums.creativecow.net/thread/2/962036
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
