Activity Forums Apple Final Cut Pro Do not have “Log & Transfer” option so can’t import footage.
  • Do not have “Log & Transfer” option so can’t import footage.
    Posted by Pat Pagano on July 31, 2012 at 11:32 am
    I’m about to buy The Canon XA10. Had opportunity to test it out….
    works well with all the bells and whistles. When trying to import
    on FCPE 10.0.0….. don’t recognize camera….and I do not have
    the option of going up to “File” and using log and transfer….because it is not in my drop down menu. Do I need to upgrade FCP….or is there another way around this? Appreciate any
    advice…including…don’t buy that camera.
    Pat
    Pat Pagano replied 14 years, 1 month ago 4 Members · 6 Replies
  • Jeremy Garchow
    July 31, 2012 at 4:05 pm
    Did you try File > Import from Camera?
  • Pat Pagano
    July 31, 2012 at 4:43 pm
    Yes….I tried…..does not acknowledge camera….goes right to
    isight……so there I am looking at myself.
    Thanks..
    Pat
  • Jeremy Garchow
    July 31, 2012 at 4:53 pm
    Try import from camera archive.
  • David Battistella
    July 31, 2012 at 4:54 pm
    Use command ALT I to import.
    Command I is set as a default to the isight camera, it’s teh very first keystroke I remapped.
    HEY APPLE, that might have been an iMove default, but a PRO default is to import a FILE with COMMAND I
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://www.davidbattistella.com
  • Claude Lyneis
    August 2, 2012 at 1:17 am
    I have an XA10, and have used it with every version of FCPX.
    Step 1.
    Plug it in using USB port and turn on you Mac
    Step 2
    Put it in play back mode and the camera should ask whether you want to access the internal memory or one of the external memory cards (if you have installed them.)
    Sep 4 Choose the memory of choice.
    At this point you should be able to do either
    A. Import using FCPX
    B. Find an icon for the memory on the Mac desk top and drag the AVCHD file onto your hard drive.
    I actually do both so I have an imported file and a “raw” AVCHD image that can be imported at any later date.
  • Pat Pagano
    August 2, 2012 at 11:39 am
    Thanks Claude…..will try that later on and let you know.
    I just bought a new IMAC…set it up yesterday….so we will try it
    all out.
    Pat
