Activity Forums Apple Final Cut Pro Legacy Do NOT! Close gaps please
  • Do NOT! Close gaps please
    Posted by Steve Coulson on October 14, 2013 at 1:56 pm
    How can I prevent fcp 7 from automatically closing the gap when I removed a selected clip from my timeline?
    I am editing a documentary. I add a sound effect of a car passing to an audio channel. Later on, I decided to remove that bit of audio and select and delete it. FCP automatically shuffles everything that is not linked together on the timeline to the left. What a giant pain. So I have built in a gap between interview clips for timing or pacing or whatever and that dissapears and any unlinked cutaway shots are also shuffled to the left of the timeline.
    I see plenty of advice here for closing the gap but haven’t seen any to help prevent that from happening. \
    This is an ongoing problem that I normally work around by relinking everything and putting the spaces/gaps back in but I’m sure this is not an efficient way to work.
    Any tips
    Steve Coulson replied 12 years, 11 months ago 5 Members · 5 Replies
  • Rainer Wirth
    October 14, 2013 at 2:48 pm
    If you lock a video/audio track the stuff stays in place without filling the gap.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Adam Taylor
    October 14, 2013 at 3:10 pm
    how are you deleting the clip?
    I have never had that happen once in the seven years i’ve been working on FCP!
    It looks like you’re using Ripple Delete (shift, delete) when you really just want to use Delete. DO not hold down the shift button.
    adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
  • Shane Ross
    October 14, 2013 at 3:11 pm
    Select the clip and press the DELETE key…the one on the main keyboard…above the RETURN key. That will remove the clip, but not close the gap. It does a LIFT and not an EXTRACT.
    Shane
    Little Frog Post
  • Warren Eig
    October 14, 2013 at 3:32 pm
    You are not just deleting the clip you are rippling the timeline. I delete all the time and the media just gets removed from the time line. Nothing ever shifts.
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.babyboompictures.com
    REEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
  • Steve Coulson
    October 16, 2013 at 8:58 am
    Dear Shane: God damn! You have solved my problem. That was a very subtle issue that I doubt I could have resolved without your specific but very simple tip. I was using the Delete key Next to the return button, but not the one on top of the return button. I had no idea there was a difference.
    Thanks to you, now I know. That was a big help.
    Cheers
    Steve
