Activity Forums VEGAS Pro Do I Really Need AAE?
  • Do I Really Need AAE?
    Posted by Tim Smith on March 1, 2012 at 2:22 pm
    I been using Sony Vegas for about 1.5 years now and I like it alot. I basically create gaming edits and montages. Alot of my peers are suggesting that I move over to AAE, suggesting that I can make far better montages with the tool.
    I was wondering your thoughts on that. Can I accomplish the same type of work with Vegas as with AAE? If I were to get the Boris plugin set for Vegas would that make it as good for effects and stuff.
    Thanks in advance
    John Rofrano replied 14 years, 6 months ago 4 Members · 15 Replies
  • 15 Replies
  • John Rofrano
    March 1, 2012 at 3:04 pm
    It all depends on what you are doing. After Effects certainly has more special FX capabilities than Vegas alone does but that’s all AE does. It’s not a video editor like Vegas. If you purchase Boris RED for Vegas Pro you would have more capabilities than AE since AE can’t do 3D titles, etc. that Boris RED can. Boris RED can also run many AE plug-ins. So the direct answer to your question is no, you don’t need AE. The real question is would you use anything that AE provides that Vegas can’t do.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tim Smith
    March 1, 2012 at 3:19 pm
    Thanks alot John, I’m going to purchase the Boris product then. I love using Vegas to edit its just lacking in the effects and motion tracking ect….. departments.
  • Steve Rhoden
    March 1, 2012 at 4:01 pm
    AE is basically for handling advanced motion graphics,
    so if you arent in that field, it isnt necessary.
    Your friends tell you to move over to AE, they are not
    advising you well, AE is not an NLE (editing software).
    Get Boris as John mentioned, and you are ok.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Tim Smith
    March 1, 2012 at 5:58 pm
    Well the Continuum Complete for Vegas Pro is a little expensive for me. I downloaded and installed the trial version of the Boris FX instead, but I don’t see anything when I open Vegas. Was there something else I was supposed to do? I did notice in the installer there was no sony vegas 64bit only 32bit(the one I chose).
  • John Rofrano
    March 1, 2012 at 7:21 pm
    [Tim Smith] “I did notice in the installer there was no sony vegas 64bit only 32bit(the one I chose).”
    Then you need to use the 32-bit version of Vegas. I don’t believe that Boris has updated the Boris FX plug-in for 64-bit yet.
    ~jr
  • Tim Smith
    March 1, 2012 at 10:45 pm
    Dumb question, will 32bit vegas work on 64bit box? If so where do I get the 32bit version. Also, is there a decrease in performance with the 32 bit versus the 64 bit?
  • John Rofrano
    March 2, 2012 at 3:54 am
    [Tim Smith] “will 32bit vegas work on 64bit box?”
    Yes 32-bit Vegas works fine on Windows 64-bit and you can have both the 32-bit version and 64-bit version of Vegas installed at the same time.
    [Tim Smith] ” If so where do I get the 32bit version.”
    You get it from the Sony downloads page.
    https://www.sonycreativesoftware.com/download/updates/vegaspro
    [Tim Smith] “Also, is there a decrease in performance with the 32 bit versus the 64 bit?”
    No, performance is about the same. The real advantage of 64-bit is that you can have larger projects because you can address more memory. Other than that, they are pretty much the same.
    ~jr
  • Tim Smith
    March 2, 2012 at 1:02 pm
    John,
    I have Vegas Pro 10. Do I have to upgrade to 11 in order to get the 32 bit version?
  • Mike Kujbida
    March 2, 2012 at 1:29 pm
    [Tim Smith] “I have Vegas Pro 10. Do I have to upgrade to 11 in order to get the 32 bit version?”
    No you don’t.
    You can find the 32 bit version at https://www.sonycreativesoftware.com/download/updates/vegasfamily
  • John Rofrano
    March 2, 2012 at 2:54 pm
    Yea, sorry I pointed you to the Vegas Pro 11 download page but you can download the 32-bit build for any version from Mike’s link.
    ~jr
