Activity Forums Apple Final Cut Pro Legacy Do I need to render the settings changes or not ?
  • Do I need to render the settings changes or not ?
    Posted by Fredy Schwerdtner on May 18, 2009 at 6:32 pm
    I’m just about to export a movie/sequence from FCP timeline as ProRes 422. The question is: Do I need to change the sequence settings to ProRes, rendedr it and then export it or during the “export as quicktime conversion ” action, it will be rendered at the end ?
    Rafael Amador replied 17 years, 4 months ago 3 Members · 6 Replies
  • Chris Poisson
    May 18, 2009 at 8:39 pm
    Yes, change the settings and render.
    Have a wonderful day.
  • Rafael Amador
    May 19, 2009 at 12:53 pm
    If you go to export by QT Conversion, the sequence codec it doesn’t matter.
    However QT Conversion is a very little recommendable path.
    rafael
    http://www.nagavideo.com
  • Fredy Schwerdtner
    May 19, 2009 at 3:53 pm
    Why is that ? What is the difference in the end ? If I change the sequence settings and render it before exporting will make differences ?
  • Rafael Amador
    May 20, 2009 at 2:07 am
    Hi Fredy,
    I don’t know much how it works QT Conversion, but you have no much control in this process.
    When you export with QT, there is ALWAYS re-compression. Even if you export with the very setting of your movie.
    In FC there is re-compression when needed. If you export with the same setting of your clip you don’t need to re-compress.
    I use QT Conversion only for fast exporting, no for full quality.
    rafael
  • Fredy Schwerdtner
    May 20, 2009 at 2:55 pm
    Thanks for the explanation of your way of doing it …..
    PS: Congratulations for your job in Laos. I saw your website.
  • Rafael Amador
    May 21, 2009 at 1:55 pm
    Thanks Fredy.
    Making videos here can be a madness but life still great.
    Cheers,
    Rafael
