Activity Forums Apple Final Cut Pro Legacy Do I need to keyframe the master fade in the audio mixer?
  • Do I need to keyframe the master fade in the audio mixer?
    Posted by Noam Osband on February 21, 2012 at 1:17 am
    I just discovered the master fade in the audio mixer. This is awesome. This should make getting sound right much easier.
    Question: do i need to do keyframes for the master fade? If I make a change in it, does it automatically apply it to the clips in some way that is visible? Im not quite sure how to use this powerful tool
    Michael Griggs replied 14 years, 2 months ago 3 Members · 2 Replies
  • Michael Gissing
    February 21, 2012 at 3:29 am
    When set to automate, the mixer adds keyframes based on your fader moves. So you can edit those keyframes later or delete or overwrite.
  • Michael Griggs
    February 21, 2012 at 9:51 pm
    The master fader in FCP does not have a writable track to record keyframes on. You’ll have to do it on the individual track level. Or mix in another app (like soundtrack pro).
