Activity Forums Adobe Premiere Pro do I need ASIO compliant sound card to output 5.1?
  • do I need ASIO compliant sound card to output 5.1?
    Posted by David Payne on January 20, 2012 at 9:39 am
    Hi all, I have recently bought surcode to edit in 5.1 and thought the best way to monitor this while editing would be with a 5.1 headset or speaker system.
    I checked my motherboard had the relevant ports (the black, pink, green, yellow etc 3.5mm audio ports) and when I saw it did I thought perfect, it’ll work.
    The speakers work very well when playing a 5.1 video in media player, but I cannot enable 5.1 within premiere. The only speaker configuration option seems to be stereo, is this because despite having the sockets my PC doesn’t have the right software to be able to do the job properly?
    If so do I need to buy a sound card and if so would a cheap one like this do the trick
    David Payne replied 11 years, 7 months ago 2 Members · 6 Replies
  • David Payne
    January 20, 2012 at 9:41 pm
    seeing as I got no reply I went out and bought a PCI sound card… I still only see 2 speakers in the audio output mapping.
    Someone please help before I waste any more money 🙁
  • Michael Buie
    March 23, 2012 at 2:41 pm
    I’m working my way through this issue as well. Some of what I’m using to make some headway:
    Specify ASIO device settings (Windows only)
    https://help.adobe.com/en_US/premierepro/cs/using/WSAC4A12C8-C7AD-4e6d-AE53-8872235DCBEC.html
    Surround sound ASIO fixed
    https://forums.adobe.com/message/2339269
    Let me know if this helps; we can compare notes.
    I think I got my issues fixed, but had to run to work before final configuration and tests
  • Michael Buie
    March 23, 2012 at 3:06 pm
    One final thing. Make sure 5.1 is selected in your control panel. Also some folk report issues using higher tham CD quality sound, so:
    Start -> Control Panel
    Hardware and Sound
    Manage Audio Devices
    Property of speakers
    Advanced tab
    use 16bit 44100hz and check both boxes
  • Michael Buie
    March 23, 2012 at 3:38 pm
    Finally, I recommend you read this post. It helped me understand how to set up the 5.1 surround in Premiere Pro better. A lot of things to line up, huh?
    Want to learn how to do Dolby 5.1 without paying for Surcode?
    https://forums.adobe.com/thread/921599
    Key points as I understand them:
    1. Your “Master” audio has to be set to 5.1 (You can’t change a sequence after the fact, so create a new Sequence and under the “Tracks” tab, make sure the master is 5.1)
    2. Your source tracks can be stereo, but once you assign the output of that track to the 5.1 Master Mix (or a Submx that is 5.1), you can use the puck control to position the audio within the sound space of the 5.1 (L Front, R Front, L Rear, R Rear, Center, Sub).
    As I read, I am recognizing I may have some research to do and challenges ensuring the exported file or created DVD plays the 5.1 surround sound. I guess I will cross that bridge when I get to it {sigh}. But, I am doing it with a very short test project … not trying to tackle the learning of this within my 1 hr 50 min movie.
    Again … I hope that helps!
  • David Payne
    April 29, 2012 at 1:32 pm
    thanks very much Michael
  • David Payne
    February 9, 2015 at 8:55 am
    well, years on and i’m still having issues with my soundblaster audigy 2 card outputting in 5.1 from premiere. It works for a while and then just stops and despite all the software showing it in 5.1 and nothing changing in the setup, I hear everything in each of the front speakers.
    Can anyone recommend a slightly better sound card that wont give me such a headache when I try to set it up?
