Activity Forums VEGAS Pro DNxHD with alpha from AE… Vegas not seeing the alpha
  • DNxHD with alpha from AE… Vegas not seeing the alpha
    Posted by Todd Morgan on August 30, 2011 at 11:47 pm
    Having issues with importing animation rendered using Avid DNxHD codec file from AE that has alpha. Reads fine back into AE, but Vegas doesn’t see the alpha. Any thoughts?
    Windows 7 and CS5
    Jeff Schroeder replied 15 years ago 2 Members · 3 Replies
  • Jeff Schroeder
    August 31, 2011 at 12:31 am
    Click on the file in project and double check (at the bottom) that is says Width x Height x 32. If it says 24, something has gone wrong.
    Put the media on the timeline then right click on the media, select properties and media tab and set the alpha channel type.
    Alpha channels are not set on by default.
    Jeff
    http://www.narrowroadmedia.com
  • Todd Morgan
    August 31, 2011 at 12:43 am
    It shows 32… tried all alpha settings. Weird. Rendered out of AE as RGB color space, tried uncompressed and compressed alpha settings within dnxhd panel…
  • Jeff Schroeder
    August 31, 2011 at 1:36 am
    I know in AE you must select RGB+Alpha, again not the default. If you did this then it’s a codec problem.
    I haven’t tried that codec, but it’s on my list of things to do.
    Sorry I couldn’t help
    Jeff
