Activity Forums Blackmagic Design DL Extreme PCIe – Premiere Serious Error II – HELP!
  • DL Extreme PCIe – Premiere Serious Error II – HELP!
    Posted by Bernie on January 5, 2006 at 6:52 am
    Good Morning.
    My name is Bernardo, i’m from Brasil and this is my
    second post here with the same subject.
    I did Try everything I could do before writing you
    again!(I spent the last 2 days installing e
    deinstalling the card, the OS(sp2 and sp1), the bios
    update, the drivers(DL 5.2.2/5.3.1) and Premiere Pro
    several times, and I allways get the same error)
    I’m really desperate. Please Help!
    I’m running DL Extreme PCIe with Premiere Pro on a
    certified Blackmagic System:
    INTEL PENTIUM DUAL CORE
    Asus P5WD2 Premium
    Intel Pentium D Dual Core 830
    3 SATA disks with 8MB cache using onboard RAID
    nVidia GeForce NX6600
    4GB DDR2 800 RAM (CORSAIR TWIN2X2048-6400PRO)
    535 watt Power supply (24 pin) – Enermax
    Premiere doesn’t stop CRASHING!
    “A serious error ocurred …”
    It seems to be a Decklink Extreme PCIe issue, because
    when I deinstall the card, I didn’t get the error
    anymore. The system get stable again.
    -I did try to install the card in all PCIe slots
    available…It did not solve the problem.
    -I did Update the Bios to the latest versios (606)
    -I did install the windows XP Sp2 and SP1 (the error
    still ocurring)
    -I did install Premiere Pro versison 1.5.1 and version
    1.5
    -When I deinstall the DL software and install only the
    blackmagic codecs I get a ” compiler error”
    -I did try to install before the Premiere Pro and
    after the DL software as you recomend on your website
    (and vice-versa).
    -I did install the latest version of DL software 5.3.1
    than I downgraded till 5.1.1
    -I guess i did all the install/deinstall combination
    possible.
    I got this card on december 2004 and since than I have
    been trying everything I could. I can see the image on
    my broadcast monitor, but every 3 minutes the system
    CRASH!
    here is the first:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=124&postid=858698
    Please Help! I don’t know anything else to do…
    thanks in advance
    Bernardo
    Peter Malakey replied 20 years, 8 months ago 8 Members · 19 Replies
  • 19 Replies
  • Chaos
    January 5, 2006 at 10:01 am
    Hi Bernardo,
    You are better than me cause at least you can install the driver, but I can’t.
    I’ve got DL SP PCIe one week ago, and still try to install it. The installation process (blue bar) goes back everytime. I’ve got recommend mainboard before buying Decklink (Asus A8N-E) and no way to install.
    I think there is a bug issue in these PCIe models. Now I am thinkink to change it with PCI model.
  • Wolf
    January 5, 2006 at 10:53 am
    Hi chaos,
    i had the same problem to install 5.3.1.
    Be sure to have quicktime installed.
    And a other trick that worked on my PC is:
    First install 5.2.2. than don
  • Bernie
    January 5, 2006 at 3:39 pm
    Hi guys.
    Still not working…
    I even try open new projects but I still getting the same error…
    I did projects with the video render set to none instead of Blackmagic codec. The render goes further but 5 minutes later I get the ” Serious Error” again…
    I realocate the card to other PCIe slot again but premiere still CRASHINHG!
    ..I don’t know what should I try now.
    thanks guys.
    We need to make it work!! Support please.
    cheers Bernardo
  • Chaos
    January 5, 2006 at 4:26 pm
    Hi all,
    still doesnt work. Even I’ve tried at different system -Asus P5AD2-E with P4- the result was little different. There was no any interruption while setup process but when I checked “Device Manager” there was an exlamation mark the place that decklink should be. As I said I think that PCIe version cards have bug inside, what is your opinion?
  • Bernie
    January 5, 2006 at 4:42 pm
    hi Chaos.
    well, can be a PCIe bug… PCIe It’s a new “enviroment”. my DL Extreme PCIe came in regular Extreme box without manual with a stick on it, saying: sorry at the time this product was made there was no manual available.
    I’m trying a new project from scratch…Now i’m rendering it none. No Blackmagic codec. It’s more stable. Now i’m getting more than 15 minutes o rendering without CRASH.
    I tell you if it done sucessfully.
    luck for us.
    cheers
    Bernardo
  • Shane Chadder
    January 5, 2006 at 8:06 pm
    Bernardo
    I’m using Decklink HD Pro 4:2:2 and version 5.1.2 was the last “stable” driver for me. With drivers 5.2 and on something changed and any significant rendering crashes premiere.
    5.2 is the version that first supported PCIe….and introduced instability for my setup.
    I wish they would publish setup specs so that we knew what the “approved systems” consisted of re: bios versions, graphics card drivers, etc. etc. I waste to much time trying to track down the problem at my end when BM must have a spec list that includes such details.
    Shane
  • Bernie
    January 5, 2006 at 10:35 pm
    I agree with you Shane.
  • Dkh Lai
    January 6, 2006 at 5:03 am
    Hi Every one,
    I have been using BMD extreme PCI & PCIe card
    on a recommended ASUS Intel Dual core system for
    about 4 months.
    Until now the “serious error” still exist and
    i sincerely hope that BMD can address this problem
    or I would suggest that we have to wait for PPro 2.0.
    My 2 cents comment
    Regards
    Daniel
  • Bernie
    January 6, 2006 at 2:00 pm
    Dear Lord! Daniel!
    4 months of ” serious error” !!!
    How you deal with your clients?
    -Sorry client, but a “serious error had ocurred” come back tomorrow, we will try make things work…
    If I do that, the clients will not come back…
    This is really Serious!
    I was thinking that I got a “bad” card…(a hardware issue)
    Now with your post I’m not sure anymore…I think the problem it’s worst than that!
    I’m running some tests with video rendering set to none( instead of using the BMD codec), and the system it’s getting more stable. Yesterday I did a 30 minutes render, without CRASH!! Yeah!
    This kind of Sucess isn’t?
    I’m reinstalling windows for the again (12 times in 3 days). I wiil start everything from the scratch using only video rendering set to none.
    I will let you guys know if I get suceed!
    cheers.
    Luck for Us
    Bernardo
    Rio de janeiro – Brasil
  • Geoff Gartside
    January 6, 2006 at 6:41 pm
    Hi all,
    DL extreme, 10bit BM codec, YUV input.
    See profile also.
    5.3.1 drivers installed OK.
    Where do I start with premiere ‘serious errors!! Ours don’t crash premiere, they just sit there until you close the box, then it closes premiere down. You can then only open a copy of the project. At the close of work we usually reach: a copy of a copy of a copy of a copy. All the copies work though.
    It does it when a frame is dropped on capture (with abort on drop checked)
    It does it sometimes when rendering (usually with 2 + video tracks involved).
    It does it occasionally when you delete a file.
    It does it often for no apparent reason.
    I don’t know why because my knowledge of computers is fairly basic, so like most other people I just guess and try ideas out.
    Why don’t Black Magic design a standard report form so that when we write in with these problems they could be assessed (hopefully) in a logical way both by BM and other readers. What about error logs etc., don’t they tell knowledgable people anything? Doesn’t system information help (if you understand it).
    It seems to me that there are a lot of people out there (here in my case) struggling with things that they cannot get to grips with.
    Thank goodness for Creative Cow.
    Thats my few pennyworth anyway!
    Cheers,
    Geoff Gartside.
