Activity Forums Blackmagic Design DL Extreme G5 2.5 DP FCP 5 –Which Codec after up grade???
  • DL Extreme G5 2.5 DP FCP 5 –Which Codec after up grade???
    Posted by Phillip Powell on April 24, 2006 at 10:24 pm
    Sorta confused, searched and couldn’t find specific answer, so if has been, please
    excuse…
    Recently upgraded to FCP 5.0.4, BM 5.5 drivers, OSX 10.4.5.
    Which codec to use now for component BetaSP capture and sequence settings?
    A lot of stuff I work on also has a mix of DVCam, BetaSP and whatever else clients
    can throw at me in same seq, if it matters.
    Uncompressed 8 bit 4:2:2? Black Magic 8 bit (2Vuy)? Don’t mind renders if there’s
    one that’s better quality if it matters.
    p2
    Phillip Powell replied 20 years, 4 months ago 2 Members · 2 Replies
  • Kristian Lam
    April 24, 2006 at 11:20 pm
    Use the Apple Uncompressed 4:2:2 codec at 8 or 10 bits. This is the dfault we use when youy configure your project using our easy setups (Final Cut Pro > Easy Setups)
    regards
    Kristian Lam
    Blackmagic Design
  • Phillip Powell
    April 25, 2006 at 4:21 pm
    Will do.
    p2
