Activity Forums Blackmagic Design DL Extreem and Sony UVW-1800p sync
  • DL Extreem and Sony UVW-1800p sync
    Posted by Margus Voll on November 13, 2005 at 8:23 pm
    Hi.
    I do not get my betacam in sync with DL … it wants refference signal.
    I found in DL manual that there is possibility to use
    DL card to provide a stable black signal to the deck.
    How do I do that?
    Is this only for capture or can I use this as sync for
    seeing my material on tv trough betacam.
    Or maybe I just have to get black generator.
    With card I used to have I got sync from
    composite video out to Betacam and it gave nice refference video.
    I also have Kramer transcoder but it does not give eny signal by itself. I tryed to feed signal from consumer DVD player to it but this did not help 🙁
    Any ideas?
    Margus.
    Margus Voll replied 20 years, 9 months ago 2 Members · 3 Replies
  • Peterson
    November 14, 2005 at 11:33 pm
    hi-
    Attach the B-Y & R-Y cables from DLink to your Betacam SP deck as usual, but take the Y component cable and instead of connecting it to the Y component input, run it instead to the ‘reference’ video input. There are two of these reference video BNCs, one above the other. Now attach the DLink Y to the bottom ‘reference’, then attach a separate short bnc cable from the top ‘reference’ bnc back to the Y component input. You have now essentially looped the Decklink Y through the reference input and should be set.
  • Margus Voll
    November 15, 2005 at 11:17 am
    Hi.
    I have ref in 2 sideways bnc connectors and 2 under them with labeled video.
    I connected Y to ref in and short bnc to video > Y and timecode on my monitor diasapears.
    Did I do it wrong?
    I even tryed Y to ref in and the other in the side from ref to Y but … no timecode also.
    Margus.
  • Margus Voll
    November 15, 2005 at 11:22 am
    No I got so far as if my premiere works then it is ok.
    When I shut it down appears Error 93 on betacam.
    Is this normal ?
    Margus.
