Divx files in Vegas?
Posted by Michael Dale on April 29, 2009 at 3:52 pmEverytime I try and open a Divx AVI file in vegas it says:
none of the files dropped on vegas pro could be opened
I’ve installed the Divx codecs and everything.
ThanksDouglas Spotted eagle replied 17 years, 4 months ago 5 Members · 4 Replies -
John Rofrano
April 29, 2009 at 4:18 pm -
Nico Stojanovski
April 30, 2009 at 9:47 amAre you sure, I think I have opened many DivX and Xvid files. Right now I have an DX50 (DivX 5.x/6.x) opened.
Try to use the K-lite codec pack.
D. Eric franks
April 30, 2009 at 1:34 pmI can also verify that it is possible to open and edit at least some DivX files, once the standard ole DivX playback codecs are installed. I have seen files that wouldn’t play and files that would only play the audio, so it’s not a simple Yes/No, but, more times than not, it seems to work.
April 30, 2009 at 2:11 pmHeya Eric! 🙂
So long as the DivX files are either older, or encoded to be compatible with DivX 5 or older, they’ll generally open in Vegas. DivX 5.2? broke the relationship. I think it was 5.2. Memory fades when it’s that far back. IIRC, they changed the way their container labeled things, but that might be wrong, too.
Douglas Spotted Eagle
VASSTCertified Sony Vegas Trainer
Aerial Camera/Instructor
