Activity › Forums › Adobe Illustrator › Distributing objects evenly along a path in Illustrator CS2
  • Distributing objects evenly along a path in Illustrator CS2
    Posted by Jamesmaby on January 4, 2007 at 8:20 pm
    I am trying to distribute a series of boxes along an uneven curve in illustrator CS2 and having no luck doing it. It’s easy to type along a path but can’t quite seem to distribute objects. Anyone got any bright ideas, please?
    Vincent Rosati replied 19 years, 8 months ago 2 Members · 1 Reply
  • Vincent Rosati
    January 8, 2007 at 6:13 pm
    You probably can drag your object into the ‘Brushes’ palette. Choose – ‘Pattern’ brush. Set the ‘Fit’ to ‘Add Space’. Now you can brush with this object, or apply the brush to an existing path.
    Hope this helps.
