Activity Forums Apple Final Cut Pro Legacy Distortions during voice over using FCP 6.0.5
  • Distortions during voice over using FCP 6.0.5
    Posted by Solange Clare on October 29, 2009 at 7:56 am
    I have faced some problems while doing voice recording. It will be great if someone could advice on these problems.
    1. Lagging/delay when recording.
    2. Distortions when recording using Final Cut Pro (FCP)/Soundtrack Pro, but things seem okay when playing back and the distortions are not recorded. I’m not sure if these are due to lagging.
    The following are the specs of the computer and the version of FCP that I’m using.
    Machine Name: Power Mac G5
    Machine Model: PowerMac 7, 3
    CPU Type: PowerPC G5 (3.0)
    CPU Speed: 2.3 GHz
    L2 Cache (per CPU): 512GB
    Memory: 2.5GB
    Bus Speed: 1.15GHz
    Boot ROM Version: 5.2 4f1
    Audio Input: AJA KONA LS
    Final Cut Pro Version: 6.0.5
    Thank you!
    Solange Clare replied 16 years, 10 months ago 2 Members · 2 Replies
  • John Fishback
    October 29, 2009 at 6:09 pm
    How are you recording? Explain what kind of mic, how’s it plugged in, etc. Lagging often happens and is called latency. Some programs have a setting that affects latency. In some cases there’s nothing you can do.
    What kind of distortion are you hearing? Distortion is not related to latency. Since the distortion is not recorded it’s probably in your monitor circuit. How are you monitoring the sound?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Solange Clare
    October 30, 2009 at 1:56 am
    We have a soundbooth with a rode mic, with a full mixer.
    We’re not sure where to set the peak levels, so they should be set at the default levels. I doubt it’s Latency, because we’re doing co-voice recording, so the voice talents are not meeting any points in the video.
    Strange “pops” are heard while recording, but yet there’re not in the recording, but they exist while playing back. Yet when I change another comp, there problem ceases.
