Activity Forums Maxon Cinema 4D Distorting a sweep without distorting the spline object
  • Distorting a sweep without distorting the spline object
    Posted by Brian Murphy on June 18, 2020 at 7:27 pm
    Hey all,
    I have many splines (connected into one spline object) configured into a grid that I have twisted with a deformer. Problem is the circle used to sweep the spline paths starts to look oblong and squished when twisted enough by the deformer so instead of clean circular wires, I have squishes (almost flattened) ones. I need to apply other twists in various areas using a falloff as well so it gets a little complicated. I don’t see any settings to maintain that circle shape. Any ideas?
    Brian
    Brian Murphy replied 6 years, 3 months ago 2 Members · 2 Replies
  • Jim Scott
    June 18, 2020 at 10:28 pm
    If I am understanding you correctly, you need to group the twist deformer only with the splines being swept. If, for example, you have grouped it in a null with all of the splines, including the circle making up the contour spline, you will get the result you describe. If this doesn’t help, perhaps you could upload your project file, or at least a simplified version showing the issue.
    Something like this:
    Not like this:
  • Brian Murphy
    June 19, 2020 at 9:49 pm
    This makes sense. Thank you Jim!
