Activity Forums Adobe After Effects Distorted “pixelated” footage
  • Distorted “pixelated” footage
    Posted by Matthew Kasey on March 12, 2010 at 7:56 pm
    I’m working on AE CS4, and this just recently started happening. When I have quicktimes in Animation or Uncompressed Standard Def, the image becomes all blocky and jagged, like it’s being pixelated. I at first thought the Mosaic filter was on. This is very strange, no other footage looks this way. I’ve tried reinterpreting the footage, making sure I’m viewing it in Full quality, etc, but no luck. Anyone have any ideas?
    I’m not sure how to post an images on here, but if someone could let me know how, I will.
    Charlie Atlas replied 16 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Greg Neumayer
    March 12, 2010 at 10:55 pm
    Check the icons above your posting text field for adding images.
    Antifreeze Design
    https://www.antifreezedesign.com
  • Michael Szalapski
    March 15, 2010 at 2:17 pm
    Just to double-check, your comp window is set to full res, right?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Matthew Kasey
    March 15, 2010 at 4:54 pm
    Yep, comp window is at full-res. Whats really weird is that only these quicktimes are looking strange. I have other graphics made in AE and Photoshop that look fine within the same comp.
  • Greg Neumayer
    March 15, 2010 at 5:17 pm
    My logic would say it’s your file, then. Double-check the file in other apps and see if you get the same problem. (in Quicktime or something else).
    If it looks good there, it sounds like it’s an interpretation issue. For starters, restart and clear your computer’s brain and make sure it’s not just being a freak on import. Sometimes I run into really weird issues just because my computer gets tired of scrambling for memory.
    Antifreeze Design
  • Charlie Atlas
    April 23, 2010 at 12:19 am
    Sometime in the last few weeks I began to have exactly the problem that Matthew described. I have been troubleshooting with every technique I can think of, but without success. I have another copy of AE CS4 on my laptop running the same OS (10.6.2) that shows the same files correctly. Everything plays fine in QT on both computers. Have anyone found an explanation or a solution to this problem?
    Charlie Atlas
  • Matthew Kasey
    April 23, 2010 at 3:13 am
    Sorry I never responded to this. I have an AJA card, and apparently the AJA AE plug ins were the problem. If you trash the plug-ins, it should alleviate the problem of the pixelated Animation footage.
  • Michael Szalapski
    April 23, 2010 at 3:15 am
    I’ve heard of AJA causing odd playback of RAM previews before, but never this. Nice catch.
    – The Great Szalam
  • Charlie Atlas
    April 24, 2010 at 6:06 pm
    Thanks that was the issue. I ran “uninstall Adobe AJA plugins” and everything is now OK.
    Charlie Atlas
